Activity Forums Adobe After Effects Pixel Per second Expression with manual stop at the end
  • Pixel Per second Expression with manual stop at the end
    Posted by Scott Smith on March 11, 2018 at 1:03 pm
    Hi
    I was using this expression to create a slideshow of images moving across the screen
    veloc = 150; //Move object 150 pixel on x axis per second
    x = position[0] + (time – inPoint) *veloc;
    y = position[1];
    [x,y]
    However I would like to be able to come to a stop at the end, I tried linking the 150 to a slider but when i animate this to zero it sends the whole thing back to the beginning.
    Reason for this is that I want consistent speed of images in different comps, however some comps have more or fewer images.
    Thanks in advance
    Walter Soyka replied 8 years, 5 months ago 3 Members · 2 Replies
  • Cassius Marques
    March 12, 2018 at 12:03 pm
    Use a slider control to drive a linear expression to transition between that value and another one of your choosing.
    something like:
    x = 0 + (time - inPoint) *veloc;
    y = position[1];
    v1=[x,y];
    v2=[value[0],y];
    linear(effect("Slider Control")("Slider"),1,0,v1,v2)
    You can then move it to where you want it to stop and just animate a slider going from 0 to 1 to make it stop there. Change the “0” value in line 2 to set where it starts.
    Cassius Marques
    http://www.zapfilmes.com
  • Walter Soyka
    March 13, 2018 at 3:24 am
    I would probably precompose and manually keyframe Time Remapping, so I could get exactly the easing curve I wanted.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
