Activity Forums Adobe After Effects Pixel Motion screws up my clip.
  • Pixel Motion screws up my clip.
    Posted by Daniel Cookies on January 21, 2013 at 7:45 pm
    I’m using After Effects CS 4.0.
    Whenever I render a clip that has Frame Blending(Pixel Motion), the clip gets messed up.
    At some moments of the clip, the top left corner in the picture(in most cases) starts shaking/trembling.
    Please help me on how I can resolve this issue, it’s really annoying and I really want to use pixel motion to make the slow motions smoother.
    Daniel Cookies replied 13 years, 7 months ago 3 Members · 5 Replies
  • Ridley Walker
    January 22, 2013 at 12:16 am
    It would be helpful to know the type of footage (avi, mov, mts etc) and whether it is a compressed file (mpg, h.264, HDV) etc.
    Without know the particulars, I suspect that you may be working with a source file with a long GOP. Since this type of footage has no actual frames and must be reconstituted in After Effects, applying frame blending or reducing the speed of the footage will produce unpredictable results like those you describe.
    If this is the case, render out the original footage in an uncompressed format, import the uncompressed file into After Effects, add this to a new Comp adjust the speed/frame blending as desired, then render that.
  • Todd Kopriva
    January 22, 2013 at 6:13 am
    The Timewarp effect uses the same underlying code as frame blending set to pixel motion, but the effect has more controls for fine tuning. Give it a shot. If you upload an example of the problem that you’re having, we may be able to help more.
    After Effects team blog
  • Daniel Cookies
    January 22, 2013 at 10:23 am
    @Ridley
    The type of footage is AVI, and I’m rendering it to Quick Time(animation). I tried rendering to other formats but the issue still appears.
    @Todd
    Thanks for the fast reply,
    I’m editing a World of Warcraft clip, here is a shot:
    https://www.youtube.com/watch?v=iqfWxmMkQ40
    You can see how the picture screws up in the top left corner and in the top right corner.
    I tried adding Time Warp but when I add this effect, the preview becomes laggy and the frames have to be rendered first before I can preview the clip, and the rendering is slow indeed.
  • Todd Kopriva
    January 23, 2013 at 2:06 am
    That is a crazily hard shot for any motion vector system to work with; it involves a lot of fast, jerky, circular motions, which are going to be very hard to track and convert to motion vectors.
  • Daniel Cookies
    January 23, 2013 at 9:49 am
    So I should skip using Frame Blending?
