Activity Forums Adobe After Effects Pixel Jitter in AE
  • Pixel Jitter in AE
    Posted by Jfmead14 on August 25, 2005 at 4:26 am
    I am rendering out a file for broadcast and am getting jittery pixels on the edges of a 3D box when it zooms into the background. Does anyone know if there is a quick fix for this?
    Cheers.
    Mylenium replied 21 years ago 2 Members · 3 Replies
  • Mylenium
    August 25, 2005 at 7:45 am
    How is the box created? If it’s made of AE layers, try using Advanced 3D instead of Standard 3D. If you’re already doing this, then I guess you’re out of luck. All you could do then is change the animation of the box/ cube. Flickering normally occurs on almost horizontal lines because the antialiasing changes between frames/ fields.
    Mylenium
    [Pour Myl
  • Jfmead14
    August 25, 2005 at 7:42 pm
    Hi, thanks for that. The box is created in 3D Max though. Would the max file need to be adjusted in this case?
  • Mylenium
    August 26, 2005 at 5:51 am
    If it’s MAX, I’m sure it would be simple to adjust. Perhaps you could also try to adjust antialiasing in a way the results are better for your needs.
    Mylenium
    [Pour Myl
