Activity Forums Adobe After Effects Pixel Bender:Droste Plugin runs slow (PC)
  • Pixel Bender:Droste Plugin runs slow (PC)
    Posted by Nathan Buege on January 8, 2009 at 7:41 pm
    Hello. I just caught Carl’s Droste effect tutorial this week and am attempting to utilizing the plugin for an animation. I have the PB toolkit installed, the droste AE plugin installed for CS4, but when I apply it to a layer, it is incredibly slow (20+ seconds per 2000×2000 frame). From the appearance of the tutorial, and other people’s comments, it seems like Pixel Bender plugins should run faster. Here are my comp (PC) details:
    CPU: 2.67 GHz Intel Core 2 Duo
    Graphics: Nvidia GeForce 7600 GT
    RAM: 2 GB
    OS: XP
    I realize my system is not exceptional, but I just wanted to see if anyone could help me pinpoint anything I might be missing. Thanks much!
    Nathan
    Carl Larsen replied 17 years, 6 months ago 4 Members · 3 Replies
  • Frank Beltran
    January 26, 2009 at 8:12 am
    Hi, haven’t tried it in AE but can’t wait to… I did it in Java
  • Eduardo Rodrigues
    March 5, 2009 at 3:53 am
    i downloaded the Pixel Bender and the Droste Plugin… but i dont know how to make it works in the after effects cs4.
    what are the steps to make it works?
    tks!
  • Carl Larsen
    March 5, 2009 at 1:09 pm
    Nathan: I recorded the tutorial while the composition was previewing at 1/4 resolution, so that might be part of the problem. I almost always work at low resolution and shift+ram preview (skip every other frame) while I’m setting things up and then only do a full res render at the end. Obviously do what you need to do in your specific situation but 20 seconds per frame sounds really slow. Have you played wint turning open gl on and off?
    Eduardo: Install the pixel bender toolkit and then drag the droste.pbk file into AE’s plugin folder. That should be it.
    Carl Larsen
    TelescopeMediaGroup.net
