Activity › Forums › Adobe After Effects › pixel aspect ration from HD to SD
  • pixel aspect ration from HD to SD
    Posted by Anhtu Vu on April 20, 2013 at 4:32 pm
    I just want to wrap my head around the aspect ratio and pixel size. I need to output an SD mov and my footages are SD and HD. If i want to retain the proper proportion of my HD footage, i must choose the NTSC DV vs NTSC DV widescreen, right ??? I assume this is because NTSC DV pixel aspect is .91 (which is closer to HD pixel aspect of 1.0) vs 1.21 for widescreen…correct ??? Thx
    John Cuevas replied 13 years, 5 months ago 3 Members · 4 Replies
  • Darby Edelen
    April 20, 2013 at 7:10 pm
    This depends on whether you’re converting the HD footage to SD widescreen or 4:3 SD letterboxed. Pick whichever comp preset is accurate for the delivery (widescreen if delivering for widescreen).
    Darby Edelen
  • Anhtu Vu
    April 20, 2013 at 10:34 pm
    since HD is 16:9 i assume NTSC Widescreen is the correct setting, but with this setting the footage looked stretched vertically. When i changed the comp to NTSC DV, i have the proper letter box image of my HD.
    So my question is, when i change the HD to SD widescreen, why does it look stretched ?? Aren’t both 16:9 proportion ?? Does this have anything to do with pixel aspect .09 vs 1.21 ???
  • John Cuevas
    April 21, 2013 at 2:44 pm
    Change your comp to the DV Widescreen preset(Cntl+K), then under the comp window you will see two arrows pointing left/right, Pixel Aspect Ratio Correction(PAR), press that and your footage should look correct.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    April 21, 2013 at 2:53 pm
    Adobe Help: Pixel aspect ratio and frame aspect ratio
    Thinkck.com
