Activity Forums Adobe Photoshop pixel aspect ration for video
  • pixel aspect ration for video
    Posted by Chris Newlin on February 16, 2006 at 2:37 am
    yes, here we go again. and appeal to the gods of pixel aspect ratio corrections….
    although this is a quirky little problem.
    I’m trying to write a little action and/or batch to process a bunch of stills for video. I know they’re in square pixels… and I know if I open a new document with a DV preset, I can easily move a square pixeled image over to the new doc and it will magically translate teh square to non-square pixels. My problem is, I have about 3 or 4 hundred stills that a client wants on a video timeline, so I’d like to save a bunch of time by resizing, rescaling, or whatever… and when writing a batch or action, I can’t find the proper tool, or I lack the proper technique to do a resize that will import into my NLE. (I’d also like to correct levels for video, etc. for the batch.)
    This has also come up for me trying to find a simple way to translate PowerPoint slides to “fit” video without a bunch of manual transfers.
    I am to the point that I’m about to export to AfterEffects, do an “interpret” and then export back out as a series of Jpegs…. but what a mess.
    anyone have an idea for a shortcut to rescaling some photos to do quick export / import to an NLE?
    PhotoShop CS1,
    Media 100 8.22
    G4 dual 1.42
    thanks kiddies…
    Jeffrey Gould replied 20 years, 7 months ago 3 Members · 4 Replies
  • Jeffrey Gould
    February 16, 2006 at 3:48 am
    Sorry I don’t have an answer, but I did come here to ask the exact opposite of what you asked. I have stills from an NLE timeline and I need to make them square square pixels for computer viewing. I’d also like to use batch processing. Thanks.
    Jeffrey S. Gould
    Action Media Productions
  • Richard Harrington
    February 16, 2006 at 3:58 am
    Download CS 2 Demo
    Use buitl in video actions (I wrote)
    Run DVD Slideshow action
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
    February 16, 2006 at 3:59 am
    Create an action that resize to 640 X 480 (or 486)
    Then use Batch command
  • Jeffrey Gould
    February 16, 2006 at 4:04 am
    Thanks Richard, I’m not sure which question your answer applies to. I do have your original photoshop book for non linear editors, I’ll check out your CS2 version.
    Jeffrey S. Gould
