Activity › Forums › Adobe After Effects › Pixel Aspect Ratio – Suggestions?
  • Pixel Aspect Ratio – Suggestions?
    Posted by Jon Finster on September 19, 2006 at 4:38 pm
    I have been mapping TIFF photos onto 3D planes in After Effects 6.5. These planes have come from my 3D software, and have been rendered at 720×534 w/ square PAR, 30fps.
    I’m now wanting to map QT files onto these 3D planes. But my QT files are 720×480 w/ non-square PAR, 29.97fps. What’s the best way to go about this, considering the different sizes, PAR, and fps???
    Thanks in advance.
    Tom Hepburn replied 20 years ago 3 Members · 5 Replies
  • Roland R. kahlenberg
    September 19, 2006 at 6:04 pm
    Always interpret the footage with their inherent PARs. When working with footage with different PARs, always work in square PAR comps. Should you need to render to a non-square PAR, then precomp the square PAR ocmp into a non-square PAR comp at the final step and render away.
    As for the different fps, I suggest you interpret the fps for your 3D rendered stuff as 29.97 – assuming that you final render will be at 29.97.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Jon Finster
    September 19, 2006 at 6:32 pm
    So it is okay to mix different PARs, as long as they’re interpreted correctly – I can drop my non-square PAR 720×480 QT movies into my square PAR 720×534 AE comp (the TIFFs & other files are all squared & 720×534 as well … only the QT is non-square & 720×480)?
    Just clarifying.
    My 3D software will only allow me to render 30fps.
    Ultimately I want to render all of this to FCP. Should I leave it up to FCP to convert everything DV 720×480?
    Thanks for the help.
    September 19, 2006 at 7:06 pm
    [Finster] “So it is okay to mix different PARs, as long as they’re interpreted correctly – I can drop my non-square PAR 720×480 QT movies into my square PAR 720×534 AE comp (the TIFFs & other files are all squared & 720×534 as well … only the QT is non-square & 720×480)?”
    Yup. Just ensure to stretch the non-square PAR layer to fit the domensions of the square PAR comp.
    If you’re ever unsure, you can easily create a perfect circle on a square PAR image (720×534 in your case) and use that as a starting point for all your tests.
    [Finster] “My 3D software will only allow me to render 30fps.”
    As long as you’rem not having to time-match to any other frame from another footage then the slight descrepancy between 29.97 and 30 fps is largely negligible.
    Just do everything in AE. I don’t use FCP so I can’t say one way or another to this Q.
    Good Luck
    Roland Kahlenberg
    broadcastGEMs
    [Finster] “Ultimately I want to render all of this to FCP. Should I leave it up to FCP to convert everything DV 720×480?”
  • Jon Finster
    September 19, 2006 at 8:01 pm
    Makes sense. Thanks again for the help Roland.
  • Tom Hepburn
    September 19, 2006 at 8:21 pm
    “My 3D software will only allow me to render 30fps”
    As long as your 3D software allows you to import sequences you are not limited to FPS. I’m assuming (always a mistake) that you are concerned about 29.97 compared to 30 fps? I would animate assuming 30 fps, and interpet that in AE at 29.97. Unless you’re lip synching there shouldn’t be a problem
    T
