Activity Forums Avid Media Composer Pixel Aspect Ratio setting for AVID to DVD?
  • Pixel Aspect Ratio setting for AVID to DVD?
    Posted by Miss Mc on July 3, 2007 at 4:04 am
    What quicktime settings do I use when exporting a piece from AVID to burn in DVD Studio Pro? Do I leave the settings to 720×486 (no crop/pad) and native aspect ratio? Or do I crop to 720×480 and export the native aspect ratio? Or do I drop to 720×480 and set to 4:3 aspect ratio?
    Miss Mc replied 19 years, 1 month ago 3 Members · 3 Replies
  • Seanski44
    July 3, 2007 at 10:01 am
    really great question.
    I can’t answer it but as I read this I’m trying yet another derivation of settings in QT export to try to get my aspect ratio to work correctly.
    I’m using Avid Pro 5.5 and RoxioEasyMedia Creator 9 (MyDVD) – I am successfully doing QT ref exports which I can make DVDs from, but struggle to get the DVD to have the correct AFD detail (Active Format Descriptor) as in, you can set the menu to be 16:9 but the pictures jump back to 4:3 on the TV, despite the QT ref file being exported as 16:9. Not sure if this is an Avid or Roxio prob!!
    hope someone else has more luck!!
  • Michael Phillips
    July 8, 2007 at 9:31 pm
    The 16:9 flag for the DVD player is set in the encoder when creating the MPEG2 file. It may not suffice to just set the authoring interface to 16:9 if the encoder does not pick it up as part of the encoding process. The QT ref only sets the playback display to be 16:9 but there is no flag for an encoder to use.
    Check your encoder settings for 16:9.
    Michael
    anything 24fps
  • Miss Mc
    July 12, 2007 at 6:01 pm
    It doesn’t seem to have made a difference. I think either way, it was resolved via Compressor.
