Activity Forums Adobe After Effects Pixel Aspect Ratio Question
  • Pixel Aspect Ratio Question
    Posted by Todd Carter on January 3, 2009 at 5:45 pm
    i’m using some square pixel artwork inside a non-square comp. (D1 NTSC) I’m wondering, do I interpret the footage as “non-square” to match the comp, or do i leave it set to square? Also the pixel apsect correction button, seems to just be more confusing. I’m never sure when it is “correcting” and when it is looking as it should. Any help would be appreciated. Thanks.
    Roland R. kahlenberg replied 17 years, 4 months ago 4 Members · 6 Replies
  • Roland R. kahlenberg
    January 4, 2009 at 5:19 am
    Unless you’re intending to do some speed related thingy, always interpret your footage at its original settings.
    I never use the pixel aspect ratio correction button thingy for the reasons you have alluded to.
    I always work in square-pixel comps until I am ready to render. At this stage, I nest my square-pixel comps into its relevant non square-pixel aspect ratio comp and render that out.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Scott Roberts
    January 4, 2009 at 11:06 am
    “I always work in square-pixel comps until I am ready to render. At this stage, I nest my square-pixel comps into its relevant non square-pixel aspect ratio comp and render that out. ”
    Roland, can you please elaborate on this?
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
    https://www.myr3d.com
    January 4, 2009 at 11:55 am
    Hi Scott, for PAL the non-square output, which is prevalent these days, is 720×576. It’s square PAR ‘cousin’ is 768s576.
    So, I work within a 768×576 comp throughout the project – precomps and ‘final comp’. When it comes time perform a final render, I nest the 768×576 comp into a 720×576 comp and render this out.
    Take note the CS4 does some changes to PAR and comp sizes – so the values I’ve stated will not tally for CS4 users. But the methodology is still correct.
    HTH
    RoRK
  • Todd Carter
    January 4, 2009 at 4:29 pm
    appreciate the responses. One question that i still have… in this scenario i have some non-square footage that has to be mixed with some square graphics. Would you still recommend doing all the work in a square pixel comp, then before a final render… nesting into a non-square comp? If so, in what kind of scenario would you interpret footage from non-square to square or reverse? thanks for your help, and sorry about the confusion…
  • David Ghast
    January 4, 2009 at 8:52 pm
    Try it both ways and see which one turns out better.
    January 4, 2009 at 10:11 pm
    [Todd Carter] “in what kind of scenario would you interpret footage from non-square to square or reverse?”
    Never. Always interpret your footage based on its inherent characteristics. Changing any characteristics results in unwanted outcomes. The only exception is with framerates when one wants to lower frame rates to achice a certain effect but that’s pretty advanced stuff and theer are other ways of achieving the same result.
    [Todd Carter] “Would you still recommend doing all the work in a square pixel comp, then before a final render”
    Yes, This is common. Video is almost always 720×576 (non square PAR) while graphics from Photoshop or Illustrator are always in various sizes but always in square PAR (at least’s how I create them).
    HTH
    RoRK
