Activity Forums Adobe Premiere Pro Pixel Aspect ratio problem with Quicktime files
  • Pixel Aspect ratio problem with Quicktime files
    Posted by Simon Thompson on August 28, 2006 at 3:22 pm
    Hi folks hope you can help.
    I use Final Cut Pro (sorry!). Collegue Has taken copies of Quicktime (.mov) clips captured on FCP to edit on Premiere. Clips are DV PAL. He has imported them and says they are badly pixilated. He says clip info shows the Pixel Aspect ratio is 0.9 which I believe is NTSC. PAL should be 1.067 right? He is foolishly turning to me for answers, so I am turning to you guys! He says he has PAL project setup etc and is familiar with the software. Can you guys help me to direct him to anything obvious he is doing or do you think the problem is my end? Can he change the PAR for all the clips to 1.067?
    Thanks in advance
    Simon
    Simon Thompson replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
