Activity › Forums › Adobe After Effects › Pixel aspect ratio problem
Posted by John Mendelsohn on January 8, 2012 at 2:10 pmI’m working in a FCPX on a little movie whose dimensions are allegedly 720 by 480. When I import a still 720/480 frame created in Photoshop into the movie, it is much shorter and a bit narrower than it needs to be. I know I need to make the pixels non-square in PS, but what ratio, please? Is it, because 720 is to 480 as 3 is to 2, 1.33?
Thanks in advance.
John Mendelsohn replied 14 years, 8 months ago 3 Members · 5 Replies -
Ben G unguren
January 8, 2012 at 3:28 pmThere are multiple approaches to this problem; I like to set up a 720×534 comp in PS (that’s 4:3 with 720 in the ‘4’ spot), do all my graphics there (scale any video stills to fit the new size, etc) and then just before sending to FCP, I will save a copy and resize it to 720×480.
The mantra: Do all graphics in square-pixel land. For my part, it saves me a lot of trouble down the road.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Scott Roberts
January 8, 2012 at 9:32 pmIn Photoshop, make the dimensions of a new image 720×480, 72dpi, RGB, and in the lower section, click “Advanced” and under Pixel Aspect Ratio, select D1/DV NTSC Widescreen (1.2).
Now, that being said, sometimes you’ll get different results from different NLE’s and how they’ll handle still images. Another approach is to make your image 853×480 with a square pixel aspect ratio, or 864×480 with a square pixel aspect ratio.
Try them and see which works best for you.
John Mendelsohn
January 9, 2012 at 9:19 amVery many thanks, sir. Here’s my dilemma. I need to save the last frame of a Motion movie and then get it into Final Cut Pro, looking identical, to serve as the background therein. Any suggestions will be warmly welcomed, and gratefully received.
John Mendelsohn
January 9, 2012 at 9:26 amHi, Scott. The lower section of what (for Advanced)? What is an NLE, please?
Many thanks for your kind attention.
