Activity › Forums › Adobe After Effects › Pixel Aspect Ratio in HDV Query?
  • Pixel Aspect Ratio in HDV Query?
    Posted by Paco Sweetman on December 19, 2006 at 10:46 am
    Hello all, I’m using AE 6.5 and I wanted to import some HDV (1080i PAL) or even DVCPRO HD (1080i) into After Effects to put cinelook on it. What is the aspect ratio I should use for the project?
    Jon
    Jimmy Brunger replied 19 years, 9 months ago 2 Members · 1 Reply
  • Jimmy Brunger
    December 19, 2006 at 1:00 pm
    That should be in one of the presets in AE when you go to Composition>New Composition. It is in AE7.0 anyway.
    If not then just set it up yourself:
    1440 x 1080 width & height
    frame rate for PAL: 25
    Aspect ratio: HDV 1080/DVCPRO HD or just use 1.333
