Activity › Forums › Apple Final Cut Pro Legacy › pixel aspect ratio from After Effects to FCP
Posted by Ruston on January 1, 2007 at 2:29 amWhen setting up After Effects, what pixel aspect ration should I use to be compatible with FCP DV NTSC 720 x 480? Should I use square pixels or one of the other presets?
RustonRafael Amador replied 19 years, 8 months ago 5 Members · 4 Replies -
Jerry Hofmann
January 1, 2007 at 5:12 amDV is non square. Isn’t there a preset for a DV project in AE? I’d think you should use that.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Walter Biscardi
January 1, 2007 at 12:20 pm[Jerry Hofmann] “DV is non square. Isn’t there a preset for a DV project in AE? I’d think you should use that.”
Yep, there’s presets for most all the formats we use in FCP and I just use those.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Chris Poisson
January 1, 2007 at 2:52 pmRuston,
The guys are correct, but you should read this excellent article just the same. I re-read it every so often as it is quite a complex issue. Simple little changes can mak big changes.
https://www.creativecow.net/show.php?page=/articles/gerard_rick/pixel_madness/index.html
Rafael Amador
January 2, 2007 at 11:44 amIf you open a new Composition, when you choose a Prest, the pixel Aspect Ratio change according with the Preset. if you are working NTSC DV 720×480 (4:3) the pixesl should be D1/DV NTSC (0.9).
Salud,
Rafael
