Activity Forums Apple Final Cut Pro Legacy Pixel Aspect Ratio = 8:9 in QT Pro
  • Pixel Aspect Ratio = 8:9 in QT Pro
    Posted by Ted Kusio on December 28, 2007 at 3:23 pm
    Not quite a Final Cut Pro question, but hope it’s close enough.
    A client needs a digital spot with the following specs:
    Video frame size = 720×480 (NTSC)
    Frame per sec = 29.97
    Aspect ratio = video=4:3; pixels=8:9
    Audio = stereo
    Sample rate = 48000
    Audio bit rate = 224kbps
    Problem is I only have QuickTime Pro on hand.
    I think I’m OK w/ most settings, but the one that concerns me is the pixel aspect ratio, asking for “8:9”, not. “.9”.
    Is using the DV/DVCPRO – NTSC setting correct, along w/ setting the size at NTSC 720×480 4:3?
    Also, with an audio bit rate specified, AAC seems to be the only format that allows for 224kbs quality. Any thoughts?
    Thanks, and hope it’s OK I posted here.
    –Ted
    Richard Harrington replied 18 years, 9 months ago 3 Members · 3 Replies
  • David Battistella
    December 28, 2007 at 9:28 pm
    I would double check to see if that is a typo.
    4×3 aspect equals 0.9 pixel aspect and with the 720×480 I think you will be fine. If you use the aac encoder that will be fine too.
    I would ask about the pixel aspect, but based on the other specs it all looks standard to me.
    David
  • Ted Kusio
    December 28, 2007 at 9:41 pm
    That’s what I thought, but wasn’t sure.
    Would it matter if this is headed for a TV station in the Caribbean?
  • Richard Harrington
    January 1, 2008 at 12:24 pm
    No… its only NTSC or PAL… Caribean should be NTSC
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
