Activity Forums Apple Final Cut Pro Legacy Pixel Aspect Ratio
  • Pixel Aspect Ratio
    Posted by Martin Reuben on February 12, 2006 at 10:45 pm
    We’ve created hundreds of Photoshop frames in Lightwave at a rez of 720×480, 72dpi. When we check these files in Photoshop that is indeed the resolution. The pixels are square.
    However when these are imported into FCP the aspect ratio seems to be 640×480 when these show in the canvas. My FCP sequence settings are 720×480 (NTSC DV (3:2) and the Pixel Aspect Ration is Square. When I export a QT movie using the same settings the QT frame is 720×480 and the live image area is still 640×480. There is black on either side of the live image.
    The same frames imported and exported in Motion come out at 720×480.
    What am I doing wrong in FCP?
    Thanks so much!
    Martin Reuben
    http://www.trgstudios.com
    Ben Insler replied 20 years, 7 months ago 2 Members · 1 Reply
  • Ben Insler
    February 12, 2006 at 11:03 pm
    I’m not sure.. I always use .9 NTSC pixels, but you might want to set your sequence to be 720×480 NTSC DV (4:3) instead of 3:2.
    Good luck. I’d be interested to see how you work it out.
    Best,
    Ben Insler
    Editor
    Telemark Films
