Activity › Forums › Adobe After Effects › Pixel aspect question
  • Pixel aspect question
    Posted by Paul Holzman on April 9, 2006 at 3:14 am
    I’m confused about how to handle mixed pixel sizes in AE.
    I’ve got a talking head shot against green screen that was digitized as 720×486 .9 D1 size.
    I also have Camtasia screen capture footage that is square pixel.
    The talking head is in a comp that is 450×450 and the screen capture is in a comp that is 840×404. I used D1 and square pixels respectively for each comp.
    Both pieces need be put into a comp that is 840×404 square pixels that will then be exported to an .flv and integrated into a Flash project to be shown on a computer monitor.
    When I combine the two into a single comp that I will export as an flv, the talking head looks skinny in the square pixel comp.
    Is this correct?
    Paul Holzman replied 20 years, 5 months ago 2 Members · 2 Replies
  • Graham Quince
    April 9, 2006 at 7:21 am
    Just to check, are you definetly interpreting the footage in AE’s project window? Find the talking head, right-click and choose Interpret Footag… and change the pixel aspect ratio there.
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Paul Holzman
    April 9, 2006 at 2:14 pm
    Yes Graham,
    It’s interpreted as lower field and D1.
    Paul
