Activity Forums Adobe After Effects Pixel Aspect Madness..
  • Pixel Aspect Madness..
    Posted by Steve Lim on September 29, 2005 at 6:47 am
    Hi all,
    Sorry if this is abit off topic..
    I am having trouble understanding pixel aspect for output. We are doing 3d output for PAL widescreen output for the first time.
    From my testing, I can render out 1024×576 at square pixel aspect or 960×576 at 1.067 pixel aspect from 3d. This footage is then transferred into an After Effects composition of 1.42 PAL Widescreen aspect. Everything seems fine so long as I interpret my source footage accordingly as square or 1.067 pixel aspect.
    What confuses me is why render 1024×576 when 960×576 will do? Does the computer actually render less and do less work (faster renders). Or are more pixels somehow crammed in there? =)
    Steve.
    Roland R. kahlenberg replied 20 years, 12 months ago 3 Members · 2 Replies
  • John Dickinson
    September 29, 2005 at 7:07 am
    Not sure where you’re getting that 960 figure from. My normal workflow is 1024 x 576 (square) or 720 x 576 (non-square)…
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Roland R. kahlenberg
    September 29, 2005 at 7:58 am
    By your reasoning, you could also then render at 512×576 with a 2.0 PAR. But that would half your horizontal resolution. 960×576 with a 1.067 PAR will give you fewer pixels than a 1024×576 image. Video resolution is measured in pixels – more pixels means higher resolution.
    I’d suggest that you go the 1024×576 route to ensure that you have the maximum resolution required.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
