Activity Forums Adobe After Effects Pixel Aspect Correction
  • Pixel Aspect Correction
    Posted by Peter Jun on December 3, 2007 at 2:23 pm
    So I’m working with a HDV footage (1440 x 1080) 1.33 16:9 in After Effects.
    I’ve scaled down my composition to 1024 x 768 so I can work with the web.
    The composition looks really stretched in but once I check “Toggle Pixel Aspect Correction” it views fine.
    However I want to export a still frame to Photoshop but once I do it looks stretched in again in Photoshop. I can check fix pixel aspect correction in Photoshop as well but don’t want to do that since I want to keep my size as 1024 x 768.
    How in the world would I be able to fix this? My ultimate goal is to export it in flv.
    Sam Moulton replied 18 years, 9 months ago 3 Members · 2 Replies
  • Darby Edelen
    December 3, 2007 at 4:32 pm
    Try putting your footage/composition in a 1024×576 Square Pixel composition (16:9), then select your footage/pre-comp and go to Layer > Fit To Comp.
    This should work because the 1.33 pixel aspect ratio is there to bring the acquisition aspect ratio of 4:3 (1440×1080) up to the display aspect ratio of 16:9 (1920×1080). Your footage should look correct at a 16:9 aspect ratio.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Sam Moulton
    December 3, 2007 at 4:35 pm
    For the web you want to work in a square pixel comp. Just import your HDV comp or footage into a square pixel comp and AE will handle the PAR correction automatically. Just scale the footage to either crop or fit it to the comp making sure that your X and Y scale values are identical.
