Activity Forums Adobe Photoshop pixel aspect conversion question
  • pixel aspect conversion question
    Posted by Carl Endres on April 25, 2008 at 1:04 pm
    I used a widescreen frame capture from Premiere and then brought that into Photoshop CS3 to use as a background for a composite. I did the compositing work on it, and PS shows the widescreen aspect ratio preview and it looks great.
    However, I want to print this and use it for use in a DVD cover. I have already upsized it using the 110% resampling trick.
    Before printing, what should I do to prevent the squishing, that is occuring because it is using square pixels in PS.
    Thanks in advance for any suggestions – Carl
    Richard Harrington replied 18 years, 5 months ago 2 Members · 3 Replies
  • Richard Harrington
    April 25, 2008 at 1:30 pm
    Copy the layer into a document set to square pixels and the right dimensions for your DVD label
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Carl Endres
    April 25, 2008 at 6:25 pm
    Thank You Richard, that worked great.
    April 26, 2008 at 2:02 am
    You’re welcome
