Serge Hamad
November 18, 2005 at 2:46 pmHi Y.D,
The project I posted was also made using windows and is compatible with Mac as all AE projects. You just need to download Stuffit Expander for free.
I don’t know why your blades come in “separate” Do you mean offset? However if you center all your artwork perfectly in Illustrator you should be able to import your ai file into Invigorator and have all your objects centered and ready to animate.
What version of Invigorator are you using?Here is a project and ai file: (In Zip format this time)
https://www.nyc-visual.com/Fan.zip
ai file:
https://www.nyc-visual.com/Fan_2.zip
Salut.
Serge -
Yoondo
November 19, 2005 at 12:27 am[serge] “I don’t know why your blades come in “separate” Do you mean offset?”
Hi Serge,
I meant that they all come in together, but they are separately selectable. So, there is no problem there.
I think I found the problem though. My fan did not center because I had gotten rid of the ring around the whole fan. This threw the whole thing off center because without it, the center of the fan would be off-center due to the triangular shape overall.
Thanks so much for your attention.
