Activity Forums VEGAS Pro Pitch shifting doesn’t work in Sony Vegas 13
  • Pitch shifting doesn’t work in Sony Vegas 13
    Posted by Jeroen Van weperen on March 9, 2016 at 3:34 pm
    Title pretty much sums it all up. I press the +/- key with the audio selected, but nothing happens. I’ve tried holding the ctrl, alt, shift and tab keys while pressing + and -, but nothing works.
    Does anyone know how I can fix this?
    Jeroen Van weperen replied 10 years, 6 months ago 2 Members · 3 Replies
  • Paul Berk
    March 9, 2016 at 5:44 pm
    Works for me on V13 Pro Build 453. This is one feature in Vegas I’ve never used.
  • Paul Berk
    March 9, 2016 at 5:48 pm
    Ok. I do see a problem. Initially you can change the pitch, but once changed and the focus goes elsewhere, coming back to the event it no longer responds to + or – or = .. If you add the same event back as a “take” it responds again to the new active take. I have no idea if this behavior is normal.
  • Jeroen Van weperen
    March 13, 2016 at 11:30 am
    Ah! I found the problem!I had set the pitch change to ‘Lock to stretch’, cause I liked the way it changed the pitch when I sped up/slowed down a clip. This however, prevented me from changing the pitch manually, without slowing down/speeding up the clip itself. Thanks for your reply anyways!
