Activity Forums Maxon Cinema 4D Pinning objects to extrusion
  • Pinning objects to extrusion
    Posted by Giovanni Papalia on July 19, 2021 at 2:16 pm
    Hello there!
    I am new to c4d and struggling with a (I think) fairly simple thing:
    I have an object with an animated extrusion and I need a second object to lay on top of it while it extrudes. Is there a way to pin the second obj to the extruding face so that it moves at the exact same speed?
    I am attaching two images of what I mean, hoping to make myself clear enough =)
    Thanks for the help
    Justin Thomson replied 5 years, 1 month ago 2 Members · 3 Replies
  • Justin Thomson
    July 19, 2021 at 5:10 pm
    For the secondary object. are you simply trying to have the cap of the extrude be a different material?
  • Giovanni Papalia
    July 20, 2021 at 7:11 am
    Actually yes!
  • Justin Thomson
    July 20, 2021 at 3:16 pm
    which version of c4d are you using?
