Activity Forums Maxon Cinema 4D Pinning 2 objects together
  • Pinning 2 objects together
    Posted by Richard Quinn on May 14, 2009 at 9:09 pm
    I have made a fire door which has one of those hinges at the top so the door closes again. See attached file here.
    How would I pin the two arm joints together like an elbow so the movement of one effects the other.
    I tried keyframing but they just move apart.
    Is there a tag I can use to do this?
    Any help greatly appreciated.
    Cheers,
    Rich
    Brian Jones replied 17 years, 4 months ago 3 Members · 4 Replies
  • Randy Johnson
    May 15, 2009 at 11:00 am
    There are couple ways to do this. For the best control use a combination of IK tags and constraints. Both require MOCCA. However since this is an extremely simple movement with little or no variation you can set it up with expresso and a couple range mappers.
    There is a range mapper tutorial on the C4Dcafe that Vilandra made that might be of some help.
    I might be able to load a file a little later.
    /Randy
  • Richard Quinn
    May 15, 2009 at 11:22 am
    Thanks Randy!
  • Richard Quinn
    May 15, 2009 at 3:16 pm
    Hi Randy,
    I have given it a good crack after following the tutorial you recommended.
    I have added a user data slider that now opens the door, triggering the movement of the 2 hinges.
    How do I pin those 2 hinges together though as they are still moving apart?
    Here is my xpresso file.
    Thanks again,
    Rich
  • Brian Jones
    May 15, 2009 at 7:07 pm
    Sorry can’t develop it further (no time – heading out for the weekend) but here’s something with a couple Constraint tags that might work. They are a little off when animating in the viewport (because, I think, there’s multiple calculations going on) but should be predictable in render.
