Activity Forums Blackmagic Design Pink Snow when monitoring MBE SDI
  • Pink Snow when monitoring MBE SDI
    Posted by Chris Borjis on June 26, 2006 at 4:46 pm
    I just got our multibridge extreme hooked up to our SDI router.
    When I choose to monitor the Multribridge Extreme (FCP) output I see
    pink snow if final cut is not running.
    Is there any way to fix this?
    It looks really bad whenever I minimize final cut pro to work in another app briefly and pink snow shows on the monitor.
    Chris Borjis replied 20 years, 2 months ago 2 Members · 9 Replies
  • 9 Replies
  • Kristian Lam
    June 27, 2006 at 6:25 am
    Is this regardless of your DeckLink desktop resolution?
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    June 27, 2006 at 10:01 pm
    It only shows this on our SDI monitor.
    DVI monitoring is fine (but thats the DELL for HD work)
    we mostly do SD.
  • Kristian Lam
    June 28, 2006 at 5:38 am
    What is your desktop resolution set to for the DeckLink Video Desktop? Could it be that the card’s putting out a HD desktop while your monitor is only SD capable?
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    June 28, 2006 at 4:14 pm
    oh, do you mean when fcp is not running its trying to send the desktop out the SDI port?
    Is there any way to disable that on the sdi? I just want the screen to be black, like it did before on our Discreet *smoke.
    I do like the desktop on the LCD though.
  • Kristian Lam
    June 29, 2006 at 4:27 am
    Sorry, no way to selective disable the desktop output. You can turn it off completely using the option in the DeckLink Preferences.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    June 29, 2006 at 4:51 pm
    ok, thanks for the help Kristian.
  • Kristian Lam
    June 29, 2006 at 11:13 pm
    Actually, I might be wrong. Turn on hardware down conversion and use the SDI B output to connect to you SD monitor. This way, you can monitor SD via SDI and HD via DVI.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    June 30, 2006 at 5:45 pm
    I turned off digital desktop and that did solve the pink snow issue.
    But I like the idea you just posted.
    One thing we always wanted to do with mbe was edit in HD with the LCD showing HD footage and the SD monitor showing a hardware downconversion of the exact same thing simultaneously.
    Our clients would be quite impressed with that going.
  • Chris Borjis
    July 3, 2006 at 5:06 pm
    [Kristian Lam] “Turn on hardware down conversion and use the SDI B output to connect to you SD monitor. This way, you can monitor SD via SDI and HD via DVI.”
    I just tried this and the DVI-D displays HD but I get pink snow on the SDI CRT monitor hooked up to channel B from the MBE with hardware downconversion on. It passes through an SD signal when software downconversion is on, but then it turns the DVI-D signal into SD as well.
    Do I need to have MBE software 5.6 to make this work?
