Activity › Forums › Blackmagic Design › Pink ringing on Boris Text with Stretch transition.
Posted by Sean Lander on September 27, 2005 at 3:13 amHas anyone seen anything like this before? The resolution is 10-Bit uncompressed. Didn’t occur when I rendered it with photo jpeg.
example can be seen here at: https://www.rednail.com.au/photos/10bitfault.jpg
Sean Lander replied 20 years, 11 months ago 6 Members · 10 Replies -
Luke Maslen
September 27, 2005 at 3:37 amHi Sean,
Not only is the pink ringing odd but there appear to be all kinds of compression artefacts around the text in your image which doesn’t make sense for uncompressed material.
I would sugget reposting this question in the Boris FX forum. We just use the Apple uncompressed codecs and so this isn’t a DeckLink specific question and you may receive more help in the Boris FX forum.
Regards,
Luke Maslen
Blackmagic Design -
Sean Lander
September 27, 2005 at 3:48 amNo the compression is just from making it a JPEG. The imge in the timeline is clean as a whistle.
I am also having another MAJOR problem. Some of my images have the double border filter on them.
If I render them the border disappears! This is a really big problem as I have to deliver this online very
soon. Please help if you can. -
Luke Maslen
September 27, 2005 at 4:02 amHi Sean,
I’m not familiar with Borix FX but I’ll ask around in case anyone has any ideas. Meanwhile I suggest you repost in the Borris FX forum to increase your chances of an answer.
Regards,
Luke Maslen
Blackmagic Design -
Sean Lander
September 27, 2005 at 4:07 amIt’s not just a Boris issue. I think I have found a temporary solution. If I render in 8 BIt all is well. If I render in 10 Bit RGB all looks normal as well. Which would you suggest I go with here. This item is for broadcast internationally.
Kristian Lam
September 27, 2005 at 5:29 amHi Sean,
We are unable to replicate this. Kindly contact us at support[at]blackmagic-design.com.
If it’s possible, can you send us instructions on how to reproduce this problem?
regards
Kristian
Blackmagic Design -
Paul Provost
September 27, 2005 at 2:33 pmwhenever we use a lot of text or photoshop layers we always work in 8 bit. we have always gotten green or pink edges in 10 bit. this has been going on forever and no one seems to have an answer. sometimes rendering solves it – sometimes it doesn’t. don’t know if it’s FCP or BMD.
i have given up trying to resolve it and just work in 8 bit when necessary. -
Sean Lander
September 27, 2005 at 10:00 pmThanks. Glad at least to see that I am not alone. I have found that rendering in RGB fixes the problem.
Also the text is over an Animation file. I wonder if that is also part of the problem. I will do some tests just using straight video and see. Oh and this is PAL we are talking about here. Don’t know if that makes a difference. -
Marco Pulvirenti
September 28, 2005 at 8:37 amJust to let you guys know, I’ve had that same problem too.
Mainly on graphics or text.
Normally a pink edge, or a white line on the edge of the graphic or text.
It happens only in 10-bit uncompressed.My work around is also to change the Video Processing settings to Render in 8-bit YUV.
Would be nice if we could keep it all in 10-bit.
Marco
_______________________________
marco pulvirenti
durban, south africa
Roddy Jamieson
September 28, 2005 at 9:17 amSeems to be the same problem as my earlier post, https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=856063.
BMD have tested this and say it is an Apple bug which they have reported.Roddy Jamieson
Sean Lander
September 28, 2005 at 11:20 amOK so what are peoples thoughts on rendering in either RGB or 8 Bit? I would have thought RGB 10 Bit would be better?
