Activity Forums VEGAS Pro Pink keyframes, batch render and other questions
  • Pink keyframes, batch render and other questions
    Posted by Brad Leigh on September 20, 2013 at 11:06 pm
    Hi
    Just curious, I noticed when I reopened a vegas project some of the keyframes were pink. I don’t recall if it was track motion or event crop or plug in related, just curious.
    2) Is there a way to batch render Vegas projects?
    3) any one have the issue with vegas freezing when opening the PDF manual? Actually it opens fine it’s closing it.
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
    Graham Bernard replied 12 years, 11 months ago 3 Members · 4 Replies
  • Graham Bernard
    September 21, 2013 at 6:41 am
    Pink KFs means that you have selected one of the interpolation effects: SHARP, SMOOTH, LINEAR. PINK = SHARP
    [Brad Leigh] “2) Is there a way to batch render Vegas projects?”
    _______________________________________________________________
    Yes:-
    Vegas Main Toolbar > Tools > Scripting > Batch Render.
    I’ve got Johnny Rofrano’s Render Assistant and it has a whole load of easy to use render management tools. Check it out. And it is very affordable.
    [Brad Leigh] “3) any one have the issue with vegas freezing when opening the PDF manual? Actually it opens fine it’s closing it.
    Thanks”
    PDF isn’t a supported Format. You’re going to need to convert it to one of the RASTER graphics formats Vegas supports. Truly, I’m actually amazed you got that far! I need to go to import “Show ALL Files ” before I can even reveal a PDF in the Import Menu.
    Solution: When I’ve needed to do this I have to go via my Graphics package to convert to either PNG or PSD. Then it does work and work very well on the Vegas Timeline. Sometimes I’ve needed to do this to illustrate some of the achievements that my client had won.
    Cheers
    Grazie
  • Brad Leigh
    September 21, 2013 at 4:25 pm
    Grazie
    thanks for the info. As far as the pdf goes I wasn’t trying to import into vegas, I was trying to open the vegas help doc ( manual) it would open with vegas open but when closeing vegas would freeze up.
    thanks again
    Brad
  • Steve Rhoden
    September 21, 2013 at 5:30 pm
    No, dont have an issue when opening or closing the pdf.
    There is a Batch Render Script that comes with Vegas, but
    i have never used it. You can try it out and see.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Graham Bernard
    September 21, 2013 at 10:14 pm
    Ah! VP PDF has done this on me before now. I had to resort to tracking it down and copying it to the Desktop and opening it form there. Fortunately that behaviour has long since gone, thank goodness.
    Grazie
