  • Posted by Matt Orfalea on October 25, 2007 at 3:09 am
    I’ve noticed that when I start puppeting a layer, it stops parenting. Are there any ways around this? Is there an expression I can use that will have a layer “be parented by” (follow) a specific pin? And I’m working with 3D layers.
    Matt Orf
    Dan Ebberts replied 16 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    October 25, 2007 at 1:18 pm
    Do you want a layer to follow a pin on another layer? If so, you should be able to do it like this:
    L = thisComp.layer(“puppet layer”);
    L.toWorld(L.effect(“Puppet”).arap.mesh(“Mesh 1”).deform(“Puppet Pin 1”).position)
    Dan
  • Daniel Gies
    May 28, 2010 at 5:12 pm
    Hey I was just wondering if anyone would be able to explain the logic behind this. I don’t really understand why it works the way it does.
    Body = thisComp.layer(“FlyingBoobies”)
    Body.toWorld(Body.effect(“Puppet”).arap.mesh(“Mesh 1”).deform(“ShoulderR”).position);
    I guess I am not understanding how Body.toWorld(“”); workds. What does having the layer “Body” before toWorld do. I read the help files on the expresison and I guess I am not understanding how the relationship is influenced by placing the layer object before the “toWorld” funciton.
    No rush on thhis, just curious. I would like to understand this so that I dont have to search for it everytime I need to use something similar.
  • Dan Ebberts
    May 28, 2010 at 6:01 pm
    toWorld() translates coordinates from layer space to world space. If you don’t specify a layer object, AE assumes you mean the layer with the expression, which is not what you want in this case.
    Dan
