Activity Forums Adobe After Effects Expressions pimpin’ text animation presets
  • pimpin’ text animation presets
    Posted by Christian Tanner on August 15, 2008 at 7:55 pm
    hey guys!
    i’m trying to link a particle emitter to a “text animation preset animator”. the “typewriter” preset to be exact. i’m trying to make particles appear the exact same spot a new letter appears.
    i thought maybe i could link the x-coordinate value of the particle emitter via “if – else” expression to the percentage value of the type start animator. that would probably only work for one line at a time though. sadly enough – this is as far as i was able to figure out a solution…
    any help or a wink into the right direction would be greatly appreciated.
    tanner
    Christian Tanner replied 18 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 15, 2008 at 8:38 pm
    You might be able to make it work if you were using a mono-spaced font like courier so that you could predict the offset between characters. You could detect the line-feeds in the source text by looking for “\\r” (I think, haven’t tested it).
    Dan
  • Christian Tanner
    August 15, 2008 at 9:09 pm
    thanx dan! – i’ll try that – only out of curiosity though, as the client demands their very own font (which isn’t mono spaced i’m affraid).
    guess i have to do that one by hand…
    thanx again.
    tanner
