Activity › Forums › Apple Final Cut Pro Legacy › Pimp My MacBook Pro! – connection questions
  • Pimp My MacBook Pro! – connection questions
    Posted by Bob O’brien on November 21, 2006 at 8:29 pm
    Just received my MacBook Pro (Core 2 Duo 17″) – My first Mac laptop… beautiful machine!
    I’m testing out portable FCP editing for a job next week and have external devices connected to it as follows:
    -Seagate External HD – USB
    -Sony DSR25 DVCAM Deck – Firewire
    -USB Mouse
    -Also occassionally use a USB 1 Gb thumb drive (which of course uses up the last of the USB ports).
    Any problems with all those USB devices hooked up at once?
    I have a fully rendered DV timeline playing back, but after 10 minutes or so, I drop a frame and playback stops. It seems like the Seagate may be going to sleep, because after clicking “OK” on the dropped frame warning, the drive seems to have to spin back up when I move my timeline to another area.
    I have System Perferences to never put HD to sleep (although I doubt that affects the external HD). There doesn’t seem to be any separate control panel or software to set preferences for the Seagate. Any insight?
    Finally, I noticed that I accidentally formatted the Seagate with it being “journaled.” As I understand it, the external drive should not be journaled, right? Could this be causing the problem I described? Also, can I remove journaling wihout erasing the drive? I can transfer it all over again back and forth to my G5 if need be.
    Suggestions?
    -2 GB RAM
    -2.33 GHz
    -160 Gb HD 5400 RPM
    -Mac OS 10.4.8
    -FCP 5.1.2
    -QT 7.1.3
    Thanks in advance!
    Bob O’Brien
    Mike Parfit replied 19 years, 10 months ago 7 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    November 21, 2006 at 8:38 pm
    [Bob O’Brien] “-Seagate External HD – USB”
    USB external hard drives are not for editing video. FW400 is the minimum you want. If the drive has a FW400 or FW800 port use that.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bob O’brien
    November 21, 2006 at 8:44 pm
    Thank Walter.
    Since the laptop only has one firewire 400 port, that’s where I hook up my deck. The Seagate has both firewire 400 and USB2. Since USB2 is 480Mb/sec, isn’t it faster than firewire400?
    Bob
  • Jeff Carpenter
    November 21, 2006 at 8:56 pm
    No, USB2 is not suitable for video. You have a couple of options.
    1) If the drive has 2 firewire ports, plug the deck into the drive with firewire and the drive into the computer with firewire.
    2) If it only has 1 port, buy a firewire hub and plug the deck and the hard drive into the hub.
    3) Buy an adapter cable and plug the hard drive’s Firewire 400 cable into the laptop’s firewire 800 port. They’re backwards compatable as long as you have a 400 to 800 cable. Then use the 400 port for the deck.
  • Walter Biscardi
    November 21, 2006 at 8:57 pm
    [Bob O’Brien] “Since USB2 is 480Mb/sec, isn’t it faster than firewire400?”
    Burst speed only, not sustained. You can connect your deck to the back of the drive. Though the much better route is to get a FW800 drive.
  • Bob O’brien
    November 21, 2006 at 9:00 pm
    Shall do. Thanks guys!
    Bob
  • Editwizard1
    November 21, 2006 at 9:40 pm
    I’ve heard the same thing with FW vs. USB. Yes FW kicks USB in the throughput dept. But I’ve had great results from an external usb-powered Western Digital 60gig. The transfer rate is not fantastic – about 16MB/s but plenty for editing dv in the field. I’ve just cranked 3 different tv spots using just this setup while sitting comfortably in bed, at the car dealership waiting for an oil change, or at a coffee shop.
    No, it doesn’t keep up with a firewire drive but since it’s usb-powered its completely portable. Now I wasn’t working in HD and it wasnt’ long-form but for short stuff without a ton of footage it works great. Multiple layers do need to be rendered but most everything plays back realtime just fine on my 15.4″ MBP Core Duo 2.16 w/2 GB ram.
    I have never experienced a dropped-frame on capturing DV onto that drive.
    Also, these are the type of projects where I can transfer them to and from our big MacPro system (by keeping all footage in a single folder) and finish editing there. But what a convenience to take some work with me or work on something in the field without carrying a huge heavy FW drive or looking for a power plug.
    I’m not recommending this for your mainstay… you do need to keep higher performance drives but some of these usb’s are just so cheap for the occasional small-form use.
    Best Buy has a 60gig on sale this Friday for $50.
  • Wilsonedit
    November 21, 2006 at 10:22 pm
    A note about your external drive falling asleep – you will want to set your computer to NEVER go to sleep in your Energy Settings. I have found this is the only way to keep external drives from falling asleep.
  • Will Salley
    November 22, 2006 at 12:17 am
    Also check to see if FCP is using your Mac HD as a cache drive. Usually this presents no problems for short lengths as it can buffer this data, but can sometimes result in dropped frames when the drive can’t keep up with request from the OS, FCP and whatever else may be runnng.
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
  • Bob O’brien
    November 22, 2006 at 2:54 pm
    Thank you again to all who took the time to help.
    I transferred everything to a Lacie D2 drive with Firewire 800. The timeline seems MUCH more responsive when jumping through it… no doubt about it.
    I bought the Seagates for archiving purposes, just didn’t know the USB2 had such limitations.
    Bob
  • Walter Biscardi
    November 22, 2006 at 2:56 pm
    [Bob O’Brien] “I transferred everything to a Lacie D2 drive with Firewire 800. The timeline seems MUCH more responsive when jumping through it… no doubt about it.”
    That’s the big secret with FCP. Processor speed is actually less important than drive speed when editing. Processors render faster. Faster drives give you more realtime and better editing responsiveness.
