Activity › Forums › Compression Techniques › pillarboxing 4:3 when exporting to 16.9
  • pillarboxing 4:3 when exporting to 16.9
    Posted by Zeliha Bozkurt on June 13, 2007 at 9:52 pm
    Hi Everybody
    I am trying to export a 4:3 quicktime file to DVC PRO HD 720P 60 codec. When I do this, the picture comes all streched. Is there a setting in compressor that will take the 4.3 image and maybe pillarbox it to retain the correct ratio of hte picture.
    Many thanks.
    Zee.
    Peter Dewit replied 19 years, 3 months ago 2 Members · 1 Reply
  • Peter Dewit
    June 20, 2007 at 2:30 pm
    Your best bet may be to try to drop your image into a 16:9 DVCPRO Sequence in FCP then export that. It the sequence is tagged at 16:9 and your footage as 4:3 it should pillarbox it automatically. It will take plenty fo render time in FCP to do the sizing but it should work. Test with a small piece of footage first to be sure.
