Activity Forums Compression Techniques PID Injection: Mpeg-2 compression: Video PID, Audio PID, and PMT PID
  • PID Injection: Mpeg-2 compression: Video PID, Audio PID, and PMT PID
    Posted by Jake Hawkes on September 13, 2006 at 9:37 pm
    I have recently compressed a .MOV to Mpeg2. We loaded it onto our IPTV video server only to realize that without the “PMT PID” Program Managment Table, and hexadecimal values for the Video and Audio stream, called the video and audio PID’s the server can’t identify the two streams.
    Is there a way to inject this information into a .mpg file?
    Pad Method Cable Lab Specs (packets)
    PMT PID 1E0 Hex
    Video PID 1E1 Hex
    Audio PID 1E2 Hex
    Stream Header Intervial 100ms or less
    Yantao Song replied 11 years, 9 months ago 2 Members · 1 Reply
  • Yantao Song
    December 22, 2014 at 9:16 am
    Is that problem solved , I met the same problem . would you tell me what ‘s your solution?
    Thanks .
