Activity › Forums › VEGAS Pro › Picture Slide Show Time Duration Setting for all Pictures
  • Picture Slide Show Time Duration Setting for all Pictures
    Posted by Jeffrey Springborn on May 13, 2013 at 12:47 pm
    I am constructing a picture slide show withing Vegas, and would like ot adjust the display time across all pictures once, not invidually for each picture in the timeline. Does anyone know of there is a command or setting that can be changed to accomplish this?
    Edward Troxel replied 13 years, 4 months ago 4 Members · 6 Replies
  • Mike Kujbida
    May 13, 2013 at 4:57 pm
    Options – Preferences – Editing and adjust the length in the box as shown below.
    This screenshot is from Vegas Pro but it should be very similar to what you have.
  • Aleksey Tarasov
    May 15, 2013 at 5:00 am
    The option mentioned by Mike, is effective only for new slides that you place on the timeline. If you want to change existing images, you can use various scripts. One of them is Quick Properties from Vegasaur toolkit: https://vegasaur.com/quick-properties
  • Jeffrey Springborn
    May 15, 2013 at 12:38 pm
    Thanks! This worked!!
    May 15, 2013 at 12:41 pm
    Thanks. This looks interesting. Does this tool also allow you to automatically take space out of your timeline? For example, I was editing movie media and taking out portions here and there to reduce size. In the end, I had 20 or so gaps that I needed to push together to make it one continuous stream. I ended up working from back to front and using the “Select to End” feature to grab grab all media to right and slide it to left. Is there a tool that would automatically slide everything together and save the position of my markers?
  • Aleksey Tarasov
    May 15, 2013 at 4:11 pm
    Yes, Close Gaps one-click commands will remove all the gaps between events. It’s simple like that.
    If you want to remove all timeline gaps and automatically move markers/regions, use Project Auditor tool.
  • Edward Troxel
    May 15, 2013 at 5:47 pm
    You should also look at the original script for Vegas – Excalibur – or the second script for Vegas – Ultimate S
    Edward Troxel
