Activity Forums VEGAS Pro Picture on background
  • Picture on background
    Posted by Dirk Wellekens on January 7, 2012 at 6:45 pm
    I guess this is very basic, but I can’t figure out how to do it: I want a small picture placed in the right corner on a blue back-ground. If I put the picture on the timeline with a blue background on the track below, the picture fills the screen from top to bottom with some blue background left and right. This I understand. If I pan/crop it gets smaller, but the placement is limited by the left and right borders of the original photo. How can I put the small picture anywhere on the screen?
    I tried to do this with PIP (VASST plugin), but whatever placement I choose, the picture is always in the middle.
    Dirk Wellekens replied 14 years, 8 months ago 4 Members · 4 Replies
  • Matt Crowley
    January 7, 2012 at 6:50 pm
    You either need to change the pan/crop aspect ratio to match the project (Right-click on the pan/crop window and select “Match Output Aspect) or use track motion to move/scale the picture.
  • Stanislav Alekseev
    January 7, 2012 at 8:37 pm
    Not to distort the image you need to use track motion – which is moving the layer anywhere on the screen/zooming in without cropping (not to be confused with motion tracking)
  • Joao Souza
    January 8, 2012 at 9:03 am
    Track motion all the way.
    Just click on it and move your picture or any file to wherever you want.
  • Dirk Wellekens
    January 9, 2012 at 12:21 pm
    Track motion is, indeed, what I needed. Thanks a lot!
