Activity › Forums › Avid Media Composer › Picture-in-Picture settings
  • Picture-in-Picture settings
    Posted by Set Apart on February 6, 2008 at 10:10 pm
    Hey guys,
    I’m trying to do a simple Picture in picture effect with 3 video BOXES. I want them to look normal with equal size.
    Does anyone know the correct aspect and scaling?
    I’ve seen this effect many times on TV. I just need the right aspects so it doesn’t look stretched and everything looks smooth on a 4:3 screen.
    Grinner Hester replied 18 years, 7 months ago 2 Members · 3 Replies
  • Grinner Hester
    February 7, 2008 at 4:25 am
    don’t change the aspect ratio. Just scale em down to fit.
    I start with one, get it the size I want then reappy it to ther other two tracks, just changing it’s position. This way. all three are exactly the same, no matter what size I select.
  • Set Apart
    February 7, 2008 at 4:40 am
    Thanks.
    I just need to know how to get them all exactly even to fit perfectly with the 4:3 screen. I just figured there might have been a preset or something that I could apply.
  • Grinner Hester
    February 16, 2008 at 10:39 pm
    you’ll be re-applying the first box ya make, if that helps.
    You can just change it’s position after that.
