Activity Forums VEGAS Pro Picture in Picture question —–
  • Picture in Picture question —–
    Posted by Tinfish on March 12, 2006 at 9:57 am
    Hi folks.
    I recently used the Cookie Cutter in Vegas to make a
    picture within a picture effect. While the overall
    effect was good, I couldnt figure out how to make the
    entire picture appear in the cutout section. Instead, the
    best I could do was to pan around over the small picture
    and glimpse it in stages.
    So basically I’d like to know if there is a way to make the
    entire image (or video) insert appear in the cutout section
    using the Picture in Picture effect.
    Thanks.
    Tin
    Tinfish replied 20 years, 6 months ago 3 Members · 6 Replies
  • George Wing
    March 12, 2006 at 11:16 am
    I think you want to look up “Track Motion” in the help files. That should give you the effect you are looking for…
    Regards,
    George
  • Tinfish
    March 12, 2006 at 12:15 pm
    >I think you want to look up “Track Motion” in the help files. That >should give you the effect you are looking for…
    Regards,
    George
    Ah. Thanks George. This looks very promising (a new toy even!)
    My next question is – how do I reduce the size of the
    overlay image/video without having to keep adjusting the ratio
    sliders in the menu at the side of the Track Motion menu?
    (which seems fiddly and not sensitive enough)
    Thanks again.
    T.
  • George Wing
    March 12, 2006 at 2:25 pm
    You can set the “Lock Aspect Ratio” so when you drag a corner to resize, the AR remains constant.
    Hover your pointer over the little icons above the work area to see the little text popup helpers…
    Regards,
    George
  • Tinfish
    March 12, 2006 at 6:24 pm
    >You can set the “Lock Aspect Ratio” so when you drag a corner to >resize, the AR remains constant.
    >Hover your pointer over the little icons above the work area to see >the little text popup helpers…
    Regards,
    George
    Thanks George.
    I’m able to resize now but only in one dimension.
    i.e. I can alter the height but not the width (by hovering the pointer until a round black circle icon appears).
    Should Lock Aspect be on or off?
    Ta.
    Tin
  • Mike Kujbida
    March 12, 2006 at 6:51 pm
    Make sure you don’t have one of the “Prevent Scaling (X)or(Y)” boxes selected.
    On so that it’ll scale equally (i.e. correct aspect ratio).
    Mike
  • Tinfish
    March 12, 2006 at 8:16 pm
    >Make sure you don’t have one of the “Prevent Scaling (X)or(Y)” >boxes selected.
    >Mike
    Thanks Mike. That should do the trick I reckon.
    Great forum as ever!
    Tin
