Activity Forums Adobe Premiere Pro Picture In Picture (pip) & Stabilizing
  • Picture In Picture (pip) & Stabilizing
    Posted by Jonny Webb on March 11, 2014 at 11:04 am
    I have handheld footage of a family picnic, and I’d like a closeup ‘pip’ of a talking person.
    So I made a clip of the Talker, placed it on a new track in the timeline, and spent a looooong time keyframing the position so the head stays still (in the bottom right).
    But now I’ve discovered that i’ll have to all this keyframing again for crop, or garbage matt, as these effects follow the original overlay…
    what a pain!
    Is there an easier way of doing this?
    ++ As we’re all here, i guess we’re not all there ++
    Jonny Webb replied 12 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jonny Webb
    March 11, 2014 at 11:37 am
    Update: I tried Titler & Track Matt
    but again, the positioning is all wrong.
    i made a oval shape in Title and placed it on track 3
    -track 2, foreground, is the head (close up of someone talking)
    -track 1, background, is the background (picnic)
    i got the Track Matt Key and applied it to the head.
    Open the effects settings, and change Matt:None to Matt:Video3
    Nope – the matt moves around with the background.
    I tried all combinations, but still cant get it working…
  • Joe Barta iv
    March 11, 2014 at 1:13 pm
    Sounds like a better job for After Effects. If you have AE, watch a couple of tutorials on motion tracking and/or tracking with Mocha in AE. I’m not an AE motion effects creator, I’m an editor, but I’ve found it useful and reasonably easy to grasp some simple techniques like tracking. Much better than eternal manually key framing.
    Bars & Tone
    SALUTE!
  • Jeff Pulera
    March 11, 2014 at 3:44 pm
    You didn’t state what version of PP you have, but if you have the Warp Stabilizer effect, apply that to the person clip by itself, full screen, set to “No Motion”. Once that clip is stabilized, then EXPORT it as a new clip, then import that new, stabilized clip and use it for the PIP.
    Jeff Pulera
    Safe Harbor Computers
  • Jonny Webb
    March 11, 2014 at 5:10 pm
    Thanks for the replies,
    but i’d really like to do it in PP (version cc)
  • Jeff Pulera
    March 11, 2014 at 5:13 pm
    So use the Warp Stabilizer in CC rather than keyframing it, see post #4
    Jeff
  • Jonny Webb
    March 11, 2014 at 5:28 pm
    Thanks, but is this really the way: to export and re-import…
    It will be very tedius when i have to do this effect for many people.
    And i just had to correct some lighting, which meant re-export (as a new file) re-import and replace footage with new import…
    And with the keyframing i had my talkers face perfectly still – with warp its still-ish, but moves when the head turns…
    i really dont like this workflow 🙁
  • Jeff Pulera
    March 11, 2014 at 5:44 pm
    You could try Nesting a Sequence. In other words, create a NEW SEQUENCE for each clip you need to stabilize, add clip and apply Warp Stabilizer. Then drop that “Sequence” into the main Sequence and apply PIP and such.
    I cannot predict how Warp Stabilized clips work in Nested Sequences, especially when later applying other effects (PIP, cropping), so that is why I personally would use Export. No re-rendering after that point, the new clip is “good to go” and do what you want with it.
    Good luck
    Jeff Pulera
  • Jonny Webb
    March 12, 2014 at 11:19 am
    Thank you.
    I’ll give it a try…
