Activity Forums Compression Techniques Picture In Picture -Missing key or no key/value separator found
  • Picture In Picture -Missing key or no key/value separator found
    Posted by Tom Murr on February 15, 2012 at 3:57 am
    I would like to overlay a video within another video — I have tried the examples from the libavfilter documentation site and other examples.
    I’d like to take a 640×480 video as the main/background video and superimpose a 480z360 video in the center of the main video.
    ffmpeg -i file1.mp4 -vf “movie=file2.wmv[clip2]; [in][clip2] overlay=80:60 [out]” overlay.mp4
    I received the following error: Missing key or no key/value separator found
    ffmpeg version N-34549-g13b7781, Copyright (c) 2000-2011 the FFmpeg developers
    built on Nov 6 2011 22:02:08 with gcc 4.6.1
    configuration: –enable-gpl –enable-version3 –disable-w32threads –enable-runtime-cpudetect –enable-avisynth –enable-bzlib –enable-frei0r –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libfreetype –enable-libgsm –enable-libmp3lame –enable-libopenjpeg –enable-librtmp –enable-libschroedinger –enable-libspeex –enable-libtheora –enable-libvo-aacenc –enable-libvo-amrwbenc –enable-libvorbis –enable-libvpx –enable-libx264 –enable-libxavs –enable-libxvid –enable-zlib
    libavutil 51. 24. 0 / 51. 24. 0
    libavcodec 53. 28. 0 / 53. 28. 0
    libavformat 53. 19. 0 / 53. 19. 0
    libavdevice 53. 4. 0 / 53. 4. 0
    libavfilter 2. 47. 0 / 2. 47. 0
    libswscale 2. 1. 0 / 2. 1. 0
    libpostproc 51. 2. 0 / 51. 2. 0
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘c:\temp\videos\file1.mp4’:
    Metadata:
    major_brand : isom
    minor_version : 512
    compatible_brands: isomiso2avc1mp41
    creation_time : 1970-01-01 00:00:00
    encoder : Lavf53.19.0
    Duration: 00:00:40.66, start: 0.000000, bitrate: 232 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640×480, 97 kb/s, 30 fps, 30 tbr, 30 tbn, 60 tbc
    Metadata:
    handler_name : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 128 kb/s
    Metadata:
    handler_name :
    [buffer @ 034B5DA0] w:640 h:480 pixfmt:yuv420p tb:1/1000000 sar:0/1 sws_param:
    [movie @ 034CBC00] Missing key or no key/value separator found after key ‘tempvideosfile2.mp4’
    [movie @ 034CBBC0] Error parsing options string: ‘tempvideosfile2.mp4’
    Error initializing filter ‘movie’ with args ‘c:tempvideosfile2.mp4’
    Error opening filters!
    Stephen Dixon replied 14 years, 6 months ago 2 Members · 4 Replies
  • Stephen Dixon
    February 15, 2012 at 11:43 am
    It looks like it’s having trouble parsing the path – if you look at the line that reads Error parsing options string: 'tempvideosfile2.mp4', that looks to me like it’s interpreting the backslashes as posix style escapes. Try giving it an absolute path to the movie, and escaping your backslashes eg movie=c:\temp\videos\file2.wmv
  • Tom Murr
    February 15, 2012 at 2:08 pm
    I made a mistake on my original post — it should read
    ffmpeg -i file1.mp4 -vf “movie=file2.mp4[clip2]; [in][clip2] overlay=80:60 [out]” overlay.mp4
    Also —- after some more reading —–
    Apparently the movie referenced within the filter (i.e. after -vf) must be in the same directory as FFmpeg —- when I move the video files into the same directory as FFmpeg I receive no errors and I’m able to get the Picture-in-Picture effect —– !
    Is there a way to reference a video that is not in the FFmpeg path?
  • Tom Murr
    February 15, 2012 at 3:45 pm
    Steve wrote:
    “looks to me like it’s interpreting the backslashes as posix style escapes”
    I agree — if I run FFmpeg within the directory where the file is located then their is no path (i.e. no backslashes) and I receive no errors and it produces the desired video output.
    I tried the escape sequence you proposed but it doesn’t work on my system (.. Windows 7)…. I tried the ole double backslash // but to no avail — same error but the error now includes one of the backslashes (e.g. Error parsing options string: ‘\temp\videos\file2.mp4’). So I think you are on the right track — I just have to find the right escape sequence to work with my system..
    thanks
  • Stephen Dixon
    March 4, 2012 at 2:10 am
    It’s definitely doing something tricky with the paths. Maybe try enclosing the path in quotes. I’m sorry that I’m not much chop with windows paths.
