Activity Forums Apple Final Cut Pro Legacy Picture hiccups in exported video file, when exporting while files are in external harddrive.
  • Picture hiccups in exported video file, when exporting while files are in external harddrive.
    Posted by Jens Fougn on June 5, 2013 at 7:50 am
    Since the files take up almost 250GB in ProRes 422, I have kept all the video files and the project file on an external hard disc when I edit. This has made the play-back lagging. To save space I put down all the clips I needed at the timeline, and exported it to a large ProRes file to keep on the computers internal hard disc. From this file, I wanted to cut the rest of the movie without using the external hard drive.
    – Has the problem anything to do with the movie being exported while files and the project is on the external hard drive?
    – I did not render before I exported, can this have anything to do with the problem?
    – Does anyone know how I can fix this?
    Final Cut 7.0.3
    Macbook Pro, 8 Gb RAM, 2,53 GHz
    Western Digital – My Passport Hard Drive
    Neil Patience replied 13 years, 3 months ago 2 Members · 1 Reply
  • Neil Patience
    June 5, 2013 at 11:34 pm
    Hi Jens
    Generally speaking laggy video playback is often due to slow hard drives.
    Putting media on the internal drive is not a good idea as they are usually 5400 RPM drives and struggle to playback video while running the OS etc. Unless you happen to have an internal SSD I would avoid this.
    How is the Western Digital drive attached ? You need it to be Firewire 800 as a minimum. USB or Firewire 400 is going to choke with ProRes files. USB3 or Thunderbolt would be perfect too.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
