Activity › Forums › Apple Final Cut Pro Legacy › Picture brightness changes depending on if timeline is playing or paused
Posted by Taylor Foerster on October 23, 2015 at 6:58 pmHey all!
Been working on a project (in FCP 7) for a couple of weeks, and have been trying to cope with a playback issue. If the timeline is playing, the playback is a few clicks darker. When paused, the playback is a few clicks brighter. Because of this, it’s been an extreme hassle to color correct my shots.
Any help would be greatly appreciated. Thanks,
Taylor FoersterTaylor Foerster replied 10 years, 11 months ago 3 Members · 9 Replies -
Shane Ross
October 23, 2015 at 7:05 pmWhat is the codec of the footage you are cutting?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Taylor Foerster
October 23, 2015 at 7:27 pmThanks for the quick reply Shane.
Unfortunately, I don’t know how to find the codec of a clip. -
David Roth weiss
October 23, 2015 at 7:27 pmYour sequence settings clearly do not match your media.
In addition to answering Shane’s question, please tell us exactly what the sequence settings are as well.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los AngelesDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
David Roth weiss
October 23, 2015 at 7:31 pm[Taylor Foerster] “Unfortunately, I don’t know how to find the codec of a clip.”
Taylor, it’s listed on the FCP browser… just scroll to the right until you see the column.
If you can’t ID the codec you’re working with, you will NEVER be able to succeed with FCP or any other professional non-linear editing app.That’s fundamental to editing…
David Roth Weiss
Shane Ross
October 23, 2015 at 7:42 pmI’m guessing, based on your answer, that the clip is a raw file from a DSLR or GoPro or other camera that shoots quicktime…and that you didn’t convert it to an editing codec. FCP doesn’t work well with most camera native Quicktime formats, and this is one of the issues that pops up. You need to convert your footge to ProRes first, then import and edit in FCP. Compressor does this.
Shane
Little Frog Post
Taylor Foerster
October 23, 2015 at 7:45 pmI began using FCP no more than a month ago.
From what I think sequence setting are, mine are 1920×1080 and 23.98 fps. My codec is h.264.
Shane Ross
October 23, 2015 at 8:01 pmYeah…that’s the issue. H.264.
You need to convert the footage to ProRes 422, and then bring that footage into FCP. Drop that into a new sequence and it will make the sequence ProRes 422. Be prepared, the file size of your footage will increase by a lot.
If you want to edit H.264 native, you should look at FCP-X or Adobe Premiere Pro. FCP 7 is not only a very old application, it was discontinued over 4 years ago. And never dealt with H.264 properly.
Shane
Little Frog Post
David Roth weiss
October 23, 2015 at 8:09 pmShane and I have probably dealt with this issue over a thousand times here in the Cow with new editors like yourself. Neither of us advise that you learn to use it now, as you’ll have to learn all over again with new software. You can download a free 30-day trial of Adobe Premiere and learn properly on the latest and greatest at no charge.
David Roth Weiss
