Activity › Forums › Boris FX › PICT Files Won’t Import
  • PICT Files Won’t Import
    Posted by Aurien on May 5, 2007 at 2:42 pm
    As a new Boris user I am stumbling over a few things. The first tutorial involves importing some PICT files from the supplied folder. When I try to import them (click on V1, navigate to the files) only the single PSD in the folder is available, all the PICTS are greyed-out.
    I tried resetting Preferences to Factory Settings, but that hasn’t helped.
    Lee Berger replied 19 years, 4 months ago 2 Members · 3 Replies
  • Lee Berger
    May 6, 2007 at 4:30 pm
    Try dragging them from the finder to the track (left side of the interface where you select the type of track).
  • Aurien
    May 6, 2007 at 8:10 pm
    Well, I’ll be darned. It worked. Not that the interface shouldn’t import PICTS, but it is a perfectly effective workaround. Thanks
    Carl
  • Lee Berger
    May 6, 2007 at 9:34 pm
    I’m glad it worked out.
