Activity Forums Apple Final Cut Pro Legacy Pict file shifts on fade up
  • Pict file shifts on fade up
    Posted by Greg Ball on March 31, 2007 at 4:56 pm
    I’m trying to edit a show that starts with a simple fade up from black to the clients logo (a pict file) over a video image.
    The logo does not fade in smoothly. It has a noticible verticle shift. Any reason why? I’m editing in 8 bit uncompressed.
    Thanks.
    Neil Ryan replied 19 years, 1 month ago 7 Members · 6 Replies
  • Tom Wolsky
    March 31, 2007 at 5:03 pm
    Are you looking at the rendered output on a video monitor? Has motion been applied to the PICT? Are you working in an interlaced format?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Don Greening
    March 31, 2007 at 5:08 pm
    [Greg] “It has a noticible verticle shift. Any reason why?”
    This happens a lot before the effect is rendered, so shift to Safe RT, make sure the fade up is fully rendered then have another look.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Delusions
    March 31, 2007 at 5:13 pm
    I see this from time to time and have no explanation as
    to why it happens. I’ve worked around it by trying any
    one or more of the following:
    1. Fading up using keyframes on the opacity line of the clip
    rather than the pre-built dissolve effect.
    2. Creating a new sequence in 10-bit uncompressed, copying
    the entire 8-bit sequence into it and rendering it all out 10-bit.
    3. Bring the pict file into Photoshop and export it as a jpg or tiff.
    Good luck.
    – Michael Drucker
  • Colin Mcquillan
    March 31, 2007 at 6:36 pm
    on that note,, check the render all drop down menu (sequence > render all) and make sure that all options are checked off (have a check mark beside it),, doing a “render all” will only render all of the checked off options. what gets alot of people is the render full option is not checked,, with this option off just about everything will looked rendered and for the most part play back fine,, but during GFX transitions and a few other instances shifting will be noticed. I first discovered this with .tif GFX over video shifting a line or 2 during transitions,, found the render all was not checked,, once fixed,, all played back perfect.
    (the timeline indicator for a clip needing ‘render all’ is only a slightly different shade of grey),,
    Colin McQuillan
    Vancouver BC
  • Peter Wiggins
    April 1, 2007 at 10:38 am
    Check the field order of your clip and the sequence.
    Peter
  • Neil Ryan
    April 1, 2007 at 10:58 am
    Have you applied any filters to the pict file?
    I have seen this issue (on any type of clip – not just picts) which have a transition into a clip with a filter. . . .
