Activity Forums Adobe After Effects Expressions Pick whipping between comps. Error: Layer is missing or does not exist.
  • Pick whipping between comps. Error: Layer is missing or does not exist.
    Posted by Andreas Woelfl on November 5, 2015 at 8:28 am
    Hello everybody.
    I am trying to organize my project and divide it in separate scenes.
    Some elements will be present in every comp though. To avoid jump cuts of this elements I want to pick whip each instance of an element to the one in the fist scene.
    The idea is to keep the project as flexible as possible. So if I move an element in the first scene, every instance of the element in other scenes will change its position automatically.
    I did this already in a previous project but this time I got an error I do not understand. I pick whip the properties of the two elements and get an error telling me that the layer I just pick whipped is missing or does not exist (see adjusted screenshot).
    Anybody can tell me what I am missing.
    If there are any other suggestions how to organize elements across various scene to keep the linked to each other are am more that happy.
    Thanks a lot and greeting.
    Andreas Woelfl replied 10 years, 9 months ago 3 Members · 4 Replies
  • Miguel De mendoza
    November 5, 2015 at 9:55 am
    Can you copy here the full error code?
  • Andreas Woelfl
    November 5, 2015 at 12:40 pm
    Hey Miguel,
    here is the screenshot:
  • Xavier Gomez
    November 5, 2015 at 2:40 pm
    Can it be that the project as more than one comp named “02 Scene”, and the first one that appears in the project panel doesnt have the required layer ?
  • Andreas Woelfl
    November 16, 2015 at 11:36 am
    Hello,
    I haven’t seen your response. In order to answer the post I was making test and I just realized that the pick whip is working now. I have no idea what exactly was the problem!
    Thanks anyways for all the help!
