Activity Forums Maxon Cinema 4D Pick whip values in Cinema 4D
  • Pick whip values in Cinema 4D
    Posted by Adam Zygadlo on July 13, 2011 at 2:24 pm
    Hey everyone,
    It’s not really a problem but I were wondering if you could link a value from one object like effector to other effector? (For example linking size in Fallout tag) Similar to the pick whip in After Effects. If so, how would you make the link in Cinema 4D?
    Cheers,
    +Z
    Adam Jozef Zygadlo
    Motion Graphic Designer
    07708 124 915
    http://www.jarbrain.com
    ‘Filled with brainy goodness.’
    Oliver Smith replied 14 years, 6 months ago 4 Members · 4 Replies
  • Greg Burrus
    July 13, 2011 at 2:37 pm
    You can do this via Xpresso , https://robertleger.net/blog/ is a good place to learn.
    Or using the driver tag in the character tags menu.
    Hope this helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Adam Zygadlo
    July 13, 2011 at 3:13 pm
    Cool, I’ll definitely look into this.
    Cheers Greg for the information!
    Adam Jozef Zygadlo
    07708 124 915
  • Adam Trachtenberg
    July 13, 2011 at 4:24 pm
    Cinema also has a way to automate the Xpress setup. In this case what you would do is:
    1. right-click on the falloff size parameter (the word “size”);
    2. choose Animation>Set driver;
    3. right-click on the size parameter of the other effector;
    4. choose Animation>Set driven (absolute).
    That’s it. Absolute means that it will have exactly the same value and relative means that, whatever size it is now, it will be sized proportionately when you scale the falloff of the driver effector.
  • Oliver Smith
    March 2, 2012 at 10:24 am
    This just saved me, thanks!
