Activity › Forums › Adobe After Effects › pick whip expressions bring render time up???
  • pick whip expressions bring render time up???
    Posted by Tylor Larson on October 11, 2012 at 1:31 pm
    i cut up a photo into parts to be used as a puppet. i then placed the cut up puppet file in AE as a Composition. I then placed that puppet comp into my master composition. i then added some “slider control” effects to the puppet composition on the Master Composition. i locked the effects panel and then stepped back into my puppet comp and Pick whipped the Rotations of the puppet layers to the new sliders.
    the reason behind this was so i could pass the controls forward one composition. so if i had to make the puppet interact with something in the master composition it would be easier to set keys and adjust and move keyframes.
    what i don’t understand is why this pick whipped expression is making the render times jump up so much. or is there an easier way of doing this besides having 1000000 layers in on composition.
    Todd Kopriva replied 13 years, 11 months ago 2 Members · 1 Reply
  • Todd Kopriva
    October 11, 2012 at 2:38 pm
    You haven’t given much detail about how much of an increase in render times you’re experiencing, so it’s hard to know if this is abnormal.
    Note that evaluating expressions takes some time, and it’s common for the use of expressions to add considerably to render times.
    Also note that the use of expressions can force After Effects to render using only one process, even if you’ve enabled Render Multiple Frames Simultaneously multiprocessing. Pay attention to the Info panel for helpful messages that tell you when this is occurring.
    After Effects team blog
