Activity Forums Apple Final Cut Pro Legacy Pic files bounce
  • Pic files bounce
    Posted by Bob Vick on September 12, 2006 at 7:49 pm
    Lately, as after changing to Kona LS, I have been having trouble with pic files (w/alpha keys) after placing dissolve and wipe transitions on them. The pic will bounce and turn jagged during the transition, then straighten out after. No issues during Cinewave or Kona IO. I am not sure that KONA is the reason but I would like some suggestions.
    bob
    Bob Vick sr promo guy @ ch3 & CW wwmt tv, kalamazoo, mi
    Jeremy Garchow replied 20 years ago 5 Members · 6 Replies
  • Bouncing Account needs new email address
    September 12, 2006 at 7:53 pm
    That’s sounds like a Render issue.
    Are you sure you are rendering at the highest quality?
  • Bob Vick
    September 12, 2006 at 8:02 pm
    MY RENDER SETTING IS SET TO 100%. My Timeline is set to 10bit uncompressed. When I place the pic on the timeline I get a green bar. I force a render but the bar stays green. Thoughts?
    b
  • Mark Maness
    September 12, 2006 at 8:11 pm
    Did you set your (Sequence Settings) Video Processing tab, Motion Filtering Quality to Normal or Best?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Bob Vick
    September 12, 2006 at 8:30 pm
    Thanks Wayne.
    Never went into the video tab. I have read where the Normal is the same as the best in 4.5. And that Best is what is desired. I have corrected the current sequences and created a new easy setup.
    bob
  • Chris Borjis
    September 12, 2006 at 10:47 pm
    You may still run into issues if your graphics vertical height
    is larger than 540.
  • Jeremy Garchow
    September 13, 2006 at 1:20 am
    I bet when you installed your LS your sequence render settings got reset. If the bar is still green, you aren’t rendered. Go to sequence > render all and sequence > render selection and put a check mark next to all of the available options,
    Jeremy
