Activity › Forums › Boris FX Particle Illusion › pI3 on 64-bit Windows
Posted by Alan Lorence on October 6, 2005 at 11:15 amIs anbody using pI3 on the 64-bit version of Windows? If so, how? (What special settings are needed?)
Thanks.
Alan.
wondertouchMasterm replied 20 years, 11 months ago 3 Members · 4 Replies -
Albert Zulps
October 6, 2005 at 1:28 pmHi Alan,
I am having my computer upgraded with a new motherboard and dual boot (XP Pro and XP64). I should have this done within 2 weeks – I will install my PI 3 for both OS’s and inform you of any special requirements then.
Albert -
Masterm
October 9, 2005 at 12:52 amNo special settings are needed, i’ve been using version 3 of PI on windows x64 since Beta 1, and it’s run perfectly fine. I haven’t come into any issues whatsoever.
Albert Zulps
October 11, 2005 at 7:08 pmhi kazesama,
i will be using xp64 shortly. do you use a firewall and antivirus software? i have been holding back as norton antivirus, zone alarm etc are not supposed to be 64 bit compatable. thanks
albert -
Masterm
October 12, 2005 at 8:53 amHi zeeman,
I use Norton Antivirus 10 Corporate Edition. It has a 64-bit version avaliable, and has had so for quite a few months now. It runs fine and I have no issues with it whatsoever.
My router has a built-in hardware firewall. Because of this, I don’t bother with anything other than the default windows firewall in terms of a software firewall solution.Cheers,
Kazesama
