Activity Forums Boris FX Particle Illusion PI won’t output properly
  • PI won’t output properly
    Posted by Dan Cohen on November 22, 2013 at 10:13 pm
    Recently updated Particle Illusion, and now I can’t output anything properly or at all. Output choices window comes up as normal, and then the ‘save as’ window, but regardless of the type of output I choose, it always wants to save it as an ip3 file. Got around it slightly by manually adding .mov extension, but this does not work in the same way when add a .png extension etc. Basically nothing happens at all, and I need to remove the background and output as a .png sequence. Bug fix?
    Alan Lorence replied 12 years, 9 months ago 2 Members · 4 Replies
  • Alan Lorence
    November 22, 2013 at 11:08 pm
    Use the Save Output (aka “render”) button to create a movie or image sequence. The File – Save menu only saves the project file so you can load it later.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Dan Cohen
    November 22, 2013 at 11:24 pm
    Yes, that is what I did, problem as stated.
  • Dan Cohen
    November 22, 2013 at 11:25 pm
    Yes, that is what I did, problem as stated before.
  • Alan Lorence
    November 25, 2013 at 3:26 pm
    Email support at genarts dot com.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
