Activity › Forums › Boris FX Particle Illusion › PI Won
PI Won
Posted by Khrysller on December 2, 2005 at 4:16 amHi…
Weird… i was using PI 3 weaks ago.. then today… it
Khrysller replied 20 years, 9 months ago 3 Members · 3 Replies -
Elvis Deane
December 2, 2005 at 11:57 amUnder the pI start menu group, select “reset default settings” if its there.
If not, I think you can reset it by running “particleIllusion.exe -reset” from the command line.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures -
Alan Lorence
December 2, 2005 at 7:19 pmIf you don’t have “reset default settings” in your start menu — probably means you didn’t use the installer, which probably means you don’t have a legal copy.
You can also pass a “-reset” parameter on the command line.
Alan.
wondertouch -
Khrysller
December 3, 2005 at 10:40 pmthanks you type the ‘probably’ word…
i clean up my start menu as I can AND i let just the app.exe and delete others shortcuts……again.. thanks you type the probably word…
Khrysller
