Activity › Forums › Boris FX Particle Illusion › PI serial #
PI serial #
Posted by Paul Hansen on June 8, 2017 at 9:13 pmFrancois… I did as you suggested and filled out a form at Wondertouch requesting the reactivation of my serial # but never from them… :o(
Paul
Paul Hansen replied 9 years, 3 months ago 3 Members · 4 Replies -
David Macrae
June 9, 2017 at 3:55 pmStrange they replied to me very quickly… Did you put in your support ticket at:
as suggested by Francois. That is where I did. I was just asking because you mentioned Wondertouch and I do not know if anyone monitors that website.
Francois Blawat
June 10, 2017 at 5:18 amPaul,
That Is strange since GenArts indicated users are supposed to use that Website. Can you go here to see what GenArts is seeing: https://www.genarts.com/sn-lookup.html and type in your serial number. It should show you what system GenArt thinks Particleillusion is connected to.
Here is what I show the process of getting Assistance.
1. Go to https://support.genarts.com/
2. Click the Submit Ticket button option that is listed above: https://support.genarts.com/Tickets/Submit/RenderForm/2
3. After filling out all of the items in the questions
4. Fill out Captcha question
5. Click SubmitThen I would also suggest you send an email to genarts at support dot com to let them know you also sent them a request for assistance via their website. I really hope that Boris FX gets involved as well since it seems strange that Genarts is dropping the ball here.
Good Luck.
FixitMad -
Francois Blawat
June 10, 2017 at 6:33 amPaul,
I just had a thought (It happens sometimes!), since Boris FX bought out GenArts, if you Cannot get a response back from GenArts, I would suggest you go to this website on Boris FX to open a case (what they call a ticket): https://borisfx.com/support/open-a-case/
Under Product, you may have to fudge a bit, at least to get the request sent out since it appears they do not list Particleillusion yet on that list.
Hopefully Boris FX can reset your activation back again. Hopefully GenArts only had a “Glitch” and did not get your original response…
FixitMad -
Paul Hansen
June 12, 2017 at 7:14 pmThanks, all, Kyle at Gen Arts got it all straightened out for me!
compulsively creative
