Activity Forums Boris FX Particle Illusion pI Output size doesn’t increase in ratio – cannot get above 520×480
  • pI Output size doesn’t increase in ratio – cannot get above 520×480
    Posted by Riw Sfx on August 11, 2006 at 2:23 pm
    I have made a short project in Particle Illusion, but when I come to export I cannot maintain the correct ratio. I want 100% zoom – i.e. full 640×480 quality, but when I enter 100% the ratios I get given are 520×480 and I cannot change them. In fact, increasing the zoom level over ##% only increases the height, leaving the width contstantly at 520.
    how can I solve this please as my project is designed for 640×480
    Riw Sfx replied 20 years, 1 month ago 2 Members · 4 Replies
  • Alan Lorence
    August 11, 2006 at 3:57 pm
    Make your stage window large enough to fit a 640×480 stage at 100% zoom.
    Alan.
    wondertouch
  • Riw Sfx
    August 11, 2006 at 8:27 pm
    How do I do that please?
    I have right clicked and done Zoom to fit, but still on 100% zoom when I sleect output the max I get is 520×240, but I can get the right ration if I sleect a smaller zoom (e.g. 10% = 64×48) I have also tried zooming further out and then clicking the output button, but still making no progress
    Thanks for any ideas to fix this
  • Alan Lorence
    August 11, 2006 at 9:20 pm
    You didn’t read what I wrote.
    Make the stage window larger. Drag the edges, or use Alt-3 to zoom the stage.
    You can also use pIllusionRender.
    Alan.
    wondertouch
  • Riw Sfx
    August 12, 2006 at 9:41 am
    Thanks, sorry I didn’t understand your first response.
    The Alt-3 worked fine, then I can get back to my normal view with Alt-1
